TX1, TX2 PTT not working with DXEngineering Mag Loop power inserter
Ron K2RAS
My 6500 is connected to a DXEngineering (Pixel) amplified Mag Loop antenna. The antenna power inserter has a 'key' connector to turn off the antenna preamp when the transmitter is keyed. The voltage on the TX1 and TX2 connectors moves from just above 0 volts to about .6V when the transmitter is keyed. This voltage is below the threshold to turn off the preamp.
I believe the TX1 connection used to unkey the preamp. Is the 6500 working correctly?
Thanks, Ron / K2RAS
Thanks, Ron / K2RAS
In your Transmit Profile, have you enabled the port?0
That was it! I don't do much with profiles, I never saw the matrix screen before.
Thanks, Ron0 -
The tx set up is part of basic set up and would be remembered by the radio, even if you did not have a dedicated profile set up.0
- 113 SmartSDR+
- 921 Genius Products
- 124 Antenna Genius
