Time out timer
Ken AG2K
Does the 6600 have a time out timer for the transmit side? I recently lost my connection remotely right after pushing the tune button and had to get someone to go into the shack to shut down the radio.
Yes, I believe in Settings in the TX tab there is timeout setting.0
GO to menu in the radio and at Transmit tab you will find The Timings section has adjustments for RCA TX1, TX2 and TX3 as well as the Accessory TX, TX Delay and TX Timeout.
A wifi switch on your 12v power supply is a good idea in case something like this happens.0
I had one and it also failed. I suspect some stray RF is to blame.0
- 394 Community Topics
- 670 The Flea Market
- 177 SmartSDR+
- 453 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 80 Aurora
- 982 Maestro
- 954 Genius Products
- 350 Tuner Genius XL
- 130 Antenna Genius
- 312 Shack Infrastructure
- 218 Networking
- 146 Amateur Radio Interests
