Flexcontrol interference?
Francesco Doenz
Francesco Doenz Member ✭✭
edited August 2020 in FlexControl
As soon as I plug my Flexcontrol into my laptop ACER I get a lot of interence only on 10m that looks like this:image
What can I do to cure the problem? Many thanks in advance for your inputs!
  • Steve K9ZW
    Steve K9ZW Member ✭✭✭
    edited September 2019
    Hello Francesco
    Do you think a signal is being captured and fed into your laptop?
    Perhaps you might benefit with ferrites on the USB cable?
    Steve
    K9ZW
    Blog:  http://k9zw.wordpress.com
  • Francesco Doenz
    Thanks for your suggestion, will get some ferrites and let you know!
  • Francesco Doenz
    Waiting to get some ferrites I tightly coiled up on itself the USB cable of the Flexcontrol and got rid of the spikes...and if I uncoil it and hold it in the air the spikes are worst and change with the orientation of the cable, I assume it just takes up signals as you suggested! I am not sure if the ferrites will add something, but will anyway compare them to coiling the cable on itself and let you know!
