no power out when maestro is in ssb tune mode
Jeff
I have a Flex Maestro and 6600. I use these in combination with a KPA 500 and KAT 500 Tuner.
With the internal tuner bypassed, I used to be able to press the Tune button on the Maestro and provide a signal for the external tuner to tune when in USB or LSB mode. Now when I press the Tune button I don't get any power output from the 6600. If I change the mode on the 6600 to AM, then I do get a signal output to the external tuner.
If I bypass the external tuner and activate the internal 6600 tuner, it tunes in LSB or USB mode.
In all cases, the power output level setting in the Maestro indicates in should be transmitting with a power level of 10 watts.
When I test the tune function using SmartSDR for Windows and my PC, selecting the tune button generates a signal for my external tuner to use in LSB or USB modes.
The Maestro used to work the same way.
The 6600 provides full output when modulation is present in USB or LSB.
I am running Version 3.0.27.131 on the 6600 and Maestro.
Any ideas on how to restore this function in the Maestro?
Jeff
KD6RC
Jeff
KD6RC
My 6600M has started doing the same thing. From a power off boot, with no network connection, there is no way in SSB to get power output in TUNE. For such operations, I have to switch to CW mode.
Wayne W5GIE1 -
My 6700 is doing the same, but with SmartSDR on my main PC. TUNE works fine on my iPhone, or on a second computer running SmartSDR. Both are running 3.0.27.
my Flex 6600 does the same thing with SSB on 3.1.7 it will tune in CW but not in SSB
it goes into tune mode but no power or signal out of the radio.0
- 361 Community Topics
- 620 The Flea Market
- 8K Software
- 36 SmartSDR+
- 6.3K SmartSDR for Windows
- 416 SmartSDR for Mac
- 267 SmartSDR for iOS
- 252 SmartSDR CAT
- 188 DAX
- 378 SmartSDR API
- 9.2K Radios and Accessories
- 27 Aurora
- 224 FLEX-8000 Signature Series
- 929 Maestro
- 904 Genius Products
- 327 Tuner Genius XL
- 118 Antenna Genius
- 288 Shack Infrastructure
- 202 Networking
- 141 Contesting
- 983 Third-Party Software
