No Power Out - FT8 - on Remote Laptop
W2ECK
Have a new to me Win 10 HP Elite Laptop that I am running for remote ops with WSJT-X. Program is receiving FT8 fine but not getting any power out on my 6600. Have looked thru archives but haven't found a solutio. When the WSJTX program goes to TX, I get a red TX button on my 6600, see a spike on the spectrogram, see movement on the Vu meter in on windows sound control panel - playback panel. My Tx bandwidth is set at Lo 50 & Hi 4000. But.. I see no RF pwr out in the SSDR pwr meter or any movement in the SWR window. Have tried restarting DAX- no help. In DAX, Tx Stream is on, as is RX for slice A. Seeing same issues in Fldigi in the PSK mode. Any ideas on what may be causing the lack of power out ??
73 Paul w2eck
73 Paul w2eck
Hi Paul
First thing to confirm, does the same setup work when you are not running remote?
Do you see audio showing up in the SmartSDR DAX running on the laptop (both for local and remote)?
Make sure you have DAX TX selected as an Audio Input in SmartSDR as well.
A few screen shots do help to diagnose the problem. One of SmartSDR and another of SmartSDR DAX. It also would not hurt to see the Audio settings panel in WSJTx.
Mike0 -
It's a Windows problem. You are not getting modulating audio to rig. I ran audio troubleshooter and restarted windows a couple of times to fix it. I had same issue two weeks ago on a computer I had not used in a while.0
- Yes the same setup does work - when not remote
- Yes I do see audio in DAX when remote
- Yes Dax is selected as audio input- blue dax button is lit
- three screenshots attached
73 & tnx for help
Paul w2eck
I have restarted Windows 10 a number of times- no joy on fixing problem. What Windows setting do you think was changed for you that fixed the no power out?
tnx for help
73 Paul w2eck0 -
Thanks Paul
Can you do the same screen shot while transmitting remotely?
Mike0 -
Mike - attached pic while in Tx. btw: am using Slicemaster- not sure if that matters.
73 Paul w2eck0 -
Hi Paul
There are a few bits that help narrow this down. When you took the above picture of SSDR what does SmartSDR DAX look like? Is there Audio out showing in the TX Stream?
Transmit audio travels from WSJTx to SmartSDR DAX to the Radio. When the Radio gets the audio, it does show up in the LEVEL window.
Somewhere in between, it is getting dropped.
I have this from time to time, and my solution is to shutdown WSJT and DAX and restart them. I also use SliceMaster.
In my shot attached, we want to make sure that DAX is connected to the right thing and that you see RED TX Audio while in transmit from your remote.
Mike va3mw
Mike- it appears windows is seeing a signal but no red Tx in DAX
73 Paul w2eck
Hi Paul
Let's get a support case opened for you. I have exported this to support. Keep an eye on your email.
Mike0 -
Mike - thanks
73 Paul0 -
Thanks to a great Teamviewer session with Eric Wachsmann, we were able to solve the No Power out issue on my remote laptop when using the WSJT-X program. Turned out the issue was also causing no power out also in SSB using a USB headset and Vox. We were able to determine that some of the Audio Device names were scrambled (likely during a Windows Update). Once these were straightened out, WSJT-X worked fine. Then tried a test of the USB headset and that also worked.
The customer support provided by Flex is truly second to none. Thanks guys & girls.
73 Paul w2eck
- 376 Community Topics
- 106 SmartSDR+
- 427 SmartSDR for Mac
