have a question about flex sdr screen
Don w2xb
On my flex screen it shows the station as "desktop" How do I get my call sign on the Station title? Its the same way on cat and dx screen, not showing radio name.
Don...w2xb
Don...w2xb
If your talking about on the bottom bar just click on it and it will turn blue to edit it.
Hello Larry,
Do that, but its not doesn't stay..
Don..w2xb
Which SmartSDR version are you running?
In SSDR click on "settings" then "Radio setup" then "Radio. You'll see where to change it from there.
After typing your call sign in the box at the bottom of the SSDR screen. . . . . .
STATION: N8GD
you MUST hit the ENTER key for it to be remembered next time you start up!
To set the call in CAT and DAX, follow AI4FR's instructions above, but again, be sure to hit ENTER at the end of entering the call sign.1 -
where is ssdr located in flex?
Don..w2xb
Runnin 2.5.1.10
You can also look for 'Settings' at the top of the flex display, click on 'Radio Setup', and look for 'Nickname', in the 'Radio Identification' area. Change it then close it after you hit enter, and it should retain the 'nickname' from then on.
- 113 SmartSDR+
- 944 Maestro
