version 3 upgrade
edited April 2020 in SmartSDR for Windows
I wholly support Flex's periodic pay to upgrade model. Flex needs a revenue stream to support future development.
I have no interest in operating remotely. My shack is a one person operation.
So I know I don't need SmartLink (although I did upgrade to v2, primarily for the pop-out windows and to stay current). I'm pretty sure that I won't use Multi-Flex. Have v3 users found other features in v3 that would make it worth my while (and $200) to upgrade?
Welcome!
  • Member ✭✭
    edited August 2019
    Excellent question as I am in the same boat. I understand that there has been some improvements but at the same time, some things have become worse. For example, I upgraded to V.2.5 but quickly went back to V.2.4.9 due to the DAX RX Gain not syncing which is in the system as bug #7578. I understand that Ver. 3 also suffers from this.
  • edited August 2019
    I upgraded to v3 for Multi Flex. Not because I want to share my radio (6600M) with other users. But, to allow my GUI app to run at the same time SSDR or the M model's front panel are running. Versions prior to v3 will only run one GUI app at a time. James WD5GWY
  • Member ✭✭
    edited August 2019
    It's amazing how often this topic surfaces.  The v2 and v3 upgrades have the primary feature of SmartLink or MultiFlex (which may or may not be important to you) but there are numerous other smaller features and fixes incorporated as well.
    Since everyone's needs are different my suggestion is to read through the Version Release Notes, then make your decision as to whether an upgrade is worth it to you.  You can find v3.0.27 Release Notes here: https://www.flexradio.com/downloads/smartsdr-v3-0-27-release-notes/
  • Member ✭✭
    edited February 2020
    Thank you for the link to the release notes. What I am really looking for is first hand experience from actual users, not marketing-speak from Flex.
    FWIW, I did look at the release document in your link:
    ATU Fixes
    Fixed Persistence Restoration over a SmartLink Connection
    Quick Record/Playback defect Fixed
    Problems with transmitting out of band on 60m
    Full Duplex Operation (FDX) Fixed
    SSB Monitor Audio feature Fixed
    Bug Fixes
    Which of these are actually ** NEW ** features for someone considering upgrading. It seems like everything is fixing something that was broken and we shouldn't have to pay extra bucks to get something that we already paid for working the way it was supposed to be in the first place.
  • Member ✭✭✭✭
    edited August 2019
    If I remember correctly, I believe v2.51 had these same 'bug fixes' incorporated into it as well.
    For me, I've stayed with 2.49 for now, as I'm not a fan of the 'automatic' updating of profiles built into 2.51.  I'm hoping an option to turn this off will be included in the next 2.x version.
  • Member ✭✭
    edited August 2019
    Is there going to be another 2.x version? I haven't seen anything about that
  • Member ✭✭✭
    edited August 2019
    I guess we will find out if and when there is a release...it's for sure no one on this group will have an answer concerning an additional 2.X version release.
    Regards,
    Ronald
  • Member ✭✭✭
    edited August 2019
    3.0 works nice for me.  I do use remote but I could do that with 2.49.  The multi-flex has been interesting and one thing it does allow is I can have SSDR running on my main PC and fire it up on my laptop and it works quite well.
    You can also use a Maestro with SSDR too.  You can have your Maestro be one station, your PC another.
    I upgraded to 3.x because I want to support Flex.  Whether I choose to stay on 3.0 I still feel like supporting the company that maintains my radio is a good thing.
  • Member ✭✭✭
    edited August 2019
    The point that we are paying for fixes in a release is not seeing the full picture.
    SSDR is very complicated to code. It makes little sense to have a seperate release for both the feature sets and the fixes.
    It would be almost impossible to release a feature version, then a month later release fixes on top of the feature release. And if they could? how can you make sure every fix update will go the same as it did in the lab? The reason is because every time a fix is in play it effects how a feature works. And did the fix break something eles? So it is important to work on any fixes while working on the features at the same time even as different teams are working on different things in the code. Then as much testing is done they can see how things effect what. Then it is released as a version with features and fixes together.
    So, if you follow along you can see we are not really paying for fixes in a new version, even as it seems we are because we pay for a version that has fixes in it. They need to be together in the release, it is far more simple this way. Cost effective.
    I fully expect some more changes made in Version 2.5.1..... The main reason I think why is because Flex made v2.5.1 with the same sub system as version 3. In doing that they can work on both versions that have much in common as appose to going further back to version 2.5
    V3 upgrade?
    I like the idea of having my radio up to date under the hood, the performance things we can't see.
    I like being able to just go somewere in the house or outside and start a new session of SSDR without having to shut down the first instance in the shack.
  • Member ✭✭
    I think we are getting off the topic of my original question.
    This is directed at those who have already upgraded. What new features in version 3 have enhanced your SSDR operating experience, other than Multi-Flex and SmartLink?
  • Member ✭✭✭
    edited August 2019
    Mark,     I am not aware of any new "features" in V3 to comment on except the ones you are excluding.  I have version 3..  did I miss something else?  or is that the point you are trying to make?
    I am sure V3.X will have other features to enhance my operating experience in future releases but for now I believe the "benefits", if any, have been covered.
  • Member ✭✭
    edited August 2019
    That's interesting. Would you feel the same way if it was a Kenwood, ICOM or Yaesu?
  • Member ✭✭
    edited August 2019
    I am in the same boat as James. I don't do remote, but I do enjoy using the Maestro and SmartSDR simultaneously. That's why I upgraded to v3 and also to keep current.
    Brad, N4PYI
  • edited April 2020
    I like version 3 for the simple fact I can run FT8 on one computer while using another or my Maestro for voice QSO's.
  • Member ✭✭✭
    edited August 2019
    Pat, I probably would purchase updates from the big three as well.  But in all the years I did own a big three radio the firmware updates were almost non-existent.
    I do believe that amateur radio is for many companies a very minor part of their business.   When I lived in Seattle I met the guy that ran the Icom service center and I got to go and take a look.   The overwhelming majority of radios in for service were commercial in nature.  There was a very small section of the building with the ham radios on a a shelf waiting for repair.
    I don't know Flex's business model and how much commercial business they do versus ham but I suspect their ham related business is rather small based on price, number of hams etc.  I could be wrong.  But this causes me to want to support them while I can.
  • Member ✭✭
    edited August 2019
    Thanks for the reply.
    Can't this already be done with version 2? SmartCAT and SmartDAX do not have to be run on the same computer (or Maestro) that is controlling the Flex.
  • Member ✭✭
    edited August 2019
    You could not have SmartSDR and the Maestro connected to the radio simultaneously with version 2. You can with version 3.
    Brad N4PYI
