PowerGenius Tuner Any Update
Dennis Daniel KM6DF
Is their any update on the on PowerGenius Tuner. Is their any time line to delivery.
73's Dennis KM6DF
73's Dennis KM6DF
2
An update would be nice. The last update I read about the tuner was they would be alpha testing in the 3rd quarter. We are almost two months into the quarter so hopefully progress is being made.
It would be helpful it there was initial information on cabling, physical dimensions and prelim specs. A picture would be cool. 73 Bill4
Hi Dennis, the developers are making good progress on the device and are currently targeting to begin shipments before the end of the year. As time passes our visibility into the actual delivery dates will improve. Thanks again!1
Final dimensions, power (AC or DC?), cooling and airflow requirements including clearances, fan noise, network ports, mounting kits would all be nice to know. If I had a vote (which I don't) it would be 17" wide with rack mount ears, 12 VDC power, front air intake and rear air exit, zero clearance above and below, thermostat-controlled fans, GigE network, no Windows agent required; preferably software integrated with SSDR and with PGXL utility. 12VDC power because for me it's in a rack with a PGXL (220VAC) and an Antenna Genius (12VDC). Different supply voltages for each unit in the signal chain is a bit awkward. I wouldn't mind dry contacts to signal unit failures.0
And... the original idea was to have it outside at the antenna where it would
do the most good. So power over coax and weather-proofing would be
necessary. Integration with PGXL was assumed.
Ned, K1NJ
Thanks Matt is there any info that can be shared in the specs. A news letter would be nice going forward every couple of months.
73's Dennis
- 371 Community Topics
- 94 SmartSDR+
- 424 SmartSDR for Mac
- 270 SmartSDR for iOS
- 937 Maestro
- 54 FlexControl
- 996 Third-Party Software
