Pan Adapter bug related to Xvtr and WNB
SteveM
I'm running SmartSDR v2.4.9 and just recently got a DEMI 2m transverter (28MHz IF) connected and working with my 6500. I have noticed that if I:
1. Set the zoom out so that the entire band is visible in the pan.
2. Enable, then disable the WBN dsp function.
3. What looks like a massive IMD signal appears at the top edge of the band.
The IMD signal is not real and seems only to be an artifact within the pan. It will disappear if I do anything that "disturbs" the pan-adapter, such as, zoom in/out on the horizontal axis, maximize the SSDR window, "Restore down" the window, or re-enable WNB. Shown below is an illustration of what I see.
This is the pan zoomed out to show the entire 2m band with WNB enabled:
This is the pan after disabling WNB:
BTW, I'm using an OCI 2m band-pass filter to **** the local 100kW FM transmitter that is less than 1000' from my QTH. That filter is awesome and is the reason the 2m band-noise is so prominent in the pan adapter.
I'm thinking that Flex may just send you a new TURF file. You might want to create a help ticket for this.
- 394 Community Topics
- 670 The Flea Market
- 177 SmartSDR+
- 453 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 80 Aurora
- 982 Maestro
- 954 Genius Products
- 350 Tuner Genius XL
- 130 Antenna Genius
- 312 Shack Infrastructure
- 218 Networking
- 146 Amateur Radio Interests
