6400 - Different colors for the waterfall
N5NHJ
Member ✭✭✭
I'm tuning the 2 slices of the 6400 on the same frequency, the display settings, AGC, audio, everything has been set up the same way, but I see different colors. What am I doing wrong?
Click "DISPLAY" on the left of each slice screen and adjust to your preference.0
It could be a couple of things but allow me to assume like Maury above that something is not set the same in display settings. So in the display settings, next to the "Gain" slider, click on the colored button to be sure both are the same. It appears that one display has the "add purple" selection checked.
John,
I checked everything else but the palette and you're right, 'Deuteropia' was indeed selected on one of the two slices.
Thank you to point me to the right direction.
You're welcome and it is an easy one to miss.
Thanks for this tio. I had never noticed the choices for the color schemes.
- 650 The Flea Market
- 153 SmartSDR+
- 49 Aurora
- 964 Maestro
- 937 Genius Products
- 343 Tuner Genius XL
