FRS Forcing update to 3.0?
edited April 2020 in SmartSDR for Windows
I've been using V 2.5.1 for several weeks with my 6700 on SSDR, Maestro and SSDR iOS. This morning I turned on the radio and the Maestro. The Maestro presented a radio selection screen. I selected my radio (the only shown) and the Maestro displayed a Select a Version screen. I selected 2.5.1 which had no icons.
The Maestro began downloading.  I had to walk away, but when I came back, it looks like the Maestro had downloaded V 3.0.27 and also updated my 6700. Now the screen on the Maestro says BUY. I launched SSDR V 2.5.1 on my PC and it indicated that the radio needed to be upgraded.
Is Flex pulling a Microsoft and forcing upgrades on us? At least Microsoft doesn't force us to buy the upgrades.
Welcome!
  • Member ✭✭
    edited February 2020
    I guess it's possible that the Maestro thought I pushed the v3.0.27 button, when I actually pushed v2.5.1. Maybe the Maestro needs a confirmation screen before upgrading.
  • Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator admin
    edited August 2019
    Mark
    No change.  You get to select the version you want to run.
  • Member ✭✭✭
    edited August 2019
    Just started my Maestro/6600 and it worked as normal, loading 2.5.1.  My only thought is that perhaps your selection of 2.5.1 didn't "take," in which case the cursor would have remained on the latest level.  I have a similar problem if I use a stylus instead of my finger.  For some reason the particular stylus I have is not readily picked up by the Maestro (Ver 2) screen.
  • FlexRadio Employee, Community Manager admin
    edited April 2020
    Hello Mark,
    Thank you for posting this.
    Flex does not force upgrades for our firmware or software. I think your second post is the more likely cause.  I've learned my **** fingers are sometimes not reliable, especially for routine tasks.  Upgrade and other visual confirmations are good ideas and are on the list of UI enhancements we are considering for a future release.  Full disclosure;  enhancements like this are a usually lower priority relative to features ranked in our last survey, for example.
    Dan, N7HQ
  • Member ✭✭
    edited August 2019
    If you are "forced" to upgrade, it appears, for some reason, you were running an upgraded version of SmartSDR and didn't realize it.
  • Member ✭✭
    edited August 2019
    Once I had an episode in which the Maestro did not show a full selection of SmartSDR versions when I turned it on. I just turned it off and back on again and all was well.  Some kind of glitch maybe left over from a previous shutdown. Who knows?
  • Member ✭✭
    edited August 2019
    I am little surprised someone would take the time to post a suspected problem without disconnecting and trying to reload the proper version. It seems like it would take longer to post the question than it would to trouble shoot the problem.
    Not trying to be a ****, but i get discouraged when I see licensed amateurs in a hobby that is based on experimentation, troubleshooting and technology and won't take 5 minutes to go through the most basic diagnosis.
