RadioSport Headset
KL4QG
Electret Condenser Mic, Communications Range, Adj Question I have is when I receive mic Friday . I’ll load profile for wide range and DX -on profiles Do I enable the EQ??? Do I need to adjust the mic gain on 6400B Joe What difference on receiving station hearing the wide Range and DX modes Thanks Joe
Almost any mic will need some tweaking of the TX EQ, as well as adjustment of TX filter hi and low cut, PROC, mic levels, and DEXP in order to match your individual voice, operating style, and purpose. (Rag Chewing, DXing, Contesting, Weak signal work, ESSB, etc)
I would recommend that you begin making a Rag Chew Profile, starting with the default profile for that mic, then make the desired adjustments, and save it with another name. Then begin another profile, named for DXing, and modify it and save it.
If you need some instructions, please see my Facebook tutorials on microphone audio at Www.YouTube.com/NM9P
One of them takes you through a tour of various kinds of profiles..
Another shows you how to create a new profile from scratch for a new mic.
They are a little dated, referring to Transmit Profiles rather than Mic Profiles, because back then they were one and the same.
Good luck.
Ken - NM9P0 -
Thank everyone very helpful here0
RS Headset be here Friday I’ll load profiles on 6400B for RadioSport start there0
- 361 Community Topics
- 622 The Flea Market
- 8.1K Software
- 48 SmartSDR+
- 6.3K SmartSDR for Windows
- 180 SmartSDR for Maestro and M models
- 417 SmartSDR for Mac
- 269 SmartSDR for iOS
- 252 SmartSDR CAT
- 188 DAX
- 378 SmartSDR API
- 9.2K Radios and Accessories
- 27 Aurora
- 226 FLEX-8000 Signature Series
- 929 Maestro
- 904 Genius Products
- 327 Tuner Genius XL
- 118 Antenna Genius
- 289 Shack Infrastructure
- 203 Networking
- 141 Contesting
- 985 Third-Party Software
