6400 m operating temp exceeded reboot
David Kowell
power button red error message operating temp exceeded reboot required anyone see this one
Is the red light flashing ?
How long does this take to happen after reboot ?
6 hrs0 -
it can take 6 hrs red light comes on steady
Flashing red light or solid dim or bright red light ? Adequate ventilation around the radio ? Does this happen when radio is sitting idle or do you have to warm it up by transmitting ? There is a fan rpm sensor which will force the radio to shut down if there is a problem with the fan but this only takes a few minutes to happen. Can you hear or tell if the fan is running when you get the error message ?
I was monitoring 20 meter ssb and a popping noise started coming from the speakerAND THE WATERFALL WAS FROZEN so I shut down my relatively new (3 months) old 6400M. Normally green light started flashing red until it shut down! I tried to restart and it loaded up but no waterfall, received signals or normal functions.
I suspect it was fan failure! This 6400M was purchased new from Flex this spring.
Tom Koch W4UOC
Hi Tom, you should submit a help desk ticket right away if you have not already done so.
- 328 Community Topics
- 593 The Flea Market
- 7.8K Software
- 6.2K SmartSDR for Windows
- 396 SmartSDR for Mac
- 260 SmartSDR for iOS
- 246 SmartSDR CAT
- 179 DAX
- 369 SmartSDR API
- 9.1K Radios and Accessories
- 15 Aurora
- 160 FLEX-8000 Signature Series
- 909 Maestro
- 51 FlexControl
- 873 Genius Products
- 312 Tuner Genius XL
- 115 Antenna Genius
- 278 Shack Infrastructure
- 196 Networking
- 438 Remote Operation (SmartLink)
- 135 Contesting
- 723 Peripherals & Station Integration
- 136 Amateur Radio Interests
- 942 Third-Party Software
