Change fonts
N5NHJ
Member ✭✭✭
Hello there,
I'm running SmartSDR on a 4K monitor. Text and controls are too small. I know I can change some configurations in Windows10, but everything else, other than SmartSDR, is ok, so I don't want to modify the Windows settings. Is there anything (config file, registers..) I can play with?
73, Max
73, Max
2
Go to the exe of the program. Right-click and select Properties. Choose the Compatibility tab. Click Change high DPI settings. Put a check mark in Override high DPI scaling behaviour. Scaling should be performed by System (but you can try the other two options to see the scaling effect). This does not modify Windows settings and is only application specific. 73 de Erik EI4KF.
Hi Erik,
Thanks for your suggestion. I just came back from vacation and checked on this. Unfortunately it doesn't work for me, the DPI settings you are describing doesn't exist in my Windows10 computers.
73, Max0 -
How strange is that?! I have never seen a lack of ability to tailor Windows apps for 4K.
Unless I happen to use a Windows program that is DPI aware, I have to scale DPI for my 4K or else the text is too small.
Maybe someone will know of a different method. 73 de Erik.
I don't know...
- 378 Community Topics
- 118 SmartSDR+
- 193 DAX
- 38 Aurora
- 257 FLEX-8000 Signature Series
- 947 Maestro
- 924 Genius Products
