Change fonts
N5NHJ
N5NHJ ✭✭✭
edited February 2020 in SmartSDR for Windows
Hello there,
I'm running SmartSDR on a 4K monitor. Text and controls are too small. I know I can change some configurations in Windows10, but everything else, other than SmartSDR, is ok, so I don't want to modify the Windows settings. Is there anything (config file, registers..) I can play with?
73, Max
  • Erik EI4KF
    edited July 2019
    Go to the exe of the program. Right-click and select Properties. Choose the Compatibility tab. Click Change high DPI settings. Put a check mark in Override high DPI scaling behaviour. Scaling should be performed by System (but you can try the other two options to see the scaling effect). This does not modify Windows settings and is only application specific. 73 de Erik EI4KF.
  • N5NHJ
    N5NHJ ✭✭✭
    Hi Erik,
    Thanks for your suggestion. I just came back from vacation and checked on this. Unfortunately it doesn't work for me, the DPI settings you are describing doesn't exist in my Windows10 computers.
    73, Max
  • Erik Carling EI4KF
    Erik Carling EI4KF ✭✭✭✭
    edited July 2019
    How strange is that?! I have never seen a lack of ability to tailor Windows apps for 4K.
    Unless I happen to use a Windows program that is DPI aware, I have to scale DPI for my 4K or else the text is too small.
    Maybe someone will know of a different method. 73 de Erik.
  • N5NHJ
    N5NHJ ✭✭✭
    I don't know...
