Conections Yaesu M-100
edited December 2019 in FLEX-6000 Signature Series
Can someone help me connect the Yaesu M-100 microphone to the Flex 6400M?
Welcome!
  • Member ✭✭
    edited November 2019
    remember that the Yaesu mics have both 8pin foster and RJ45 built in.
  • Member ✭✭
    edited July 2019
    Ciao Larry, se vuoi sul mio qrz.com c'è qualche schema di applicazione sui microfoni per la serie 6000 e Maestro, forse può aiutarti, 73 Per
  • Member ✭✭
    edited July 2019
    Hi Larry, if you want on my qrz.com there is some application scheme on microphones for 6000 series and Maestro, maybe it can help you, 73 For
  • Member ✭✭
    Scusa ma era per LU5FC 73
  • Member
    edited July 2019
    Thanks. Larry. But see: "....This adapter will not work with a Condenser microphones or microphones that have a Up/Down button as there is no Bias voltage available. It will work with a Microphone with a Dynamic element. ..."
  • Member ✭✭✭
    edited July 2019
    Sorry, I thought you were refering to a MD-100.
  • Member
    edited July 2019
    ok. thanks
  • Member
    edited July 2019
    Grazie Ho visto il tuo QRZ.COM. Molto interessante proverò a collegare il mio SM-8 da Icom al flex secondo lo schema che hai lì. 73 Grazie. Jesus LU5FC
  • Member ✭✭
    edited July 2019
    Ok Jesus, 73
  • [{"insert":"yaesu md 100 direkt am originalen Handmikrofon-Kabel rj 45 angeschlossen, am 6600M, funktioniert nur PTT, kein Mikrofon Eingang, gleiches Mikrofon und Kabel funktioniert am 6400 mit yaesu 100 einwandfrei, die originalen Handmikrofone funktionieren beim 6600M und 6400. wie kan das?\n"}] DK1EHK 73
  • Member
    [{"insert":"you need connect separate cable to accessory rear the 6400 panel , m100 need 5volt , the rest is same the fhm3 , ciao \n"}]
