Just received my new Flex 6400 and Maestro. Excellent so far but hand mic is labeled FHM-3. Same p
Brian Denley KB1VBF
Previous posts suggest the -3 is functional identical to the -2 but reflects current production. More a SKU type number update than anything else. 73 Steve K9ZW0
Not sure, but should not make any difference. I would guess they use the same profile. I used a Yaesu handmade and used the Flex profile. It just uses the response profile, operationally the same. I also used the Heil profile to start with for my Shure 55SH microphone and then changed as needed.
Gene, K1GD0 -
Mine was the same way i tried the FMH-essb profile and the radio worked like a charm.0
I meant to say FHM-2 ESSB Profile0
Here is the thread confirming FHM-3 is only a stock number change from FHM-2 microphones. https://community.flexradio.com/flexradio/topics/what-profile-setting-do-i-use-for-a-microphone-that-is-not-listed-in-the-profile-settings-list 73 Steve K9ZW Blog: http://K9ZW.wordpress.com0
Probably just an issue of the people dealing with ordering the hardware, missed mentioning the model number change to the SSDR programmers.
I see FHM-2 and FHM-3 mic profiles in my list.0
Not on mine. Wonder why I am using latest smartsdr.0
3.0.270
Let me know which one you want to use and I will give you the EQ Settings.
Thanks Larry!0
I can give you the EQ settings if you let me know which you want to use.0
Actually I just compared the EQ settings for FHM-2 and its the same as the FHM-3.0
Then I am all set. Thanks!0
- 389 Community Topics
- 53 Aurora
- 971 Maestro
- 945 Genius Products
- 307 Shack Infrastructure
