Just received my new Flex 6400 and Maestro. Excellent so far but hand mic is labeled FHM-3. Same p
Brian Denley  KB1VBF
Brian Denley KB1VBF Member ✭✭
edited November 2019 in FLEX-6000 Signature Series
  • Steve K9ZW
    Steve K9ZW Member ✭✭✭
    edited July 2019
    Previous posts suggest the -3 is functional identical to the -2 but reflects current production. More a SKU type number update than anything else. 73 Steve K9ZW
  • Gene Duprey
    Gene Duprey Member ✭✭
    edited July 2019
    Not sure, but should not make any difference.  I would guess they use the same profile.  I used a Yaesu handmade and used the Flex profile.  It just uses the response profile, operationally the same.  I also used the Heil profile to start with for my Shure 55SH microphone and then changed as needed.
    Gene, K1GD
  • Ted
    Ted Member ✭✭
    edited July 2019
    Mine was the same way i tried the FMH-essb profile and the radio worked like a charm.
  • Ted
    Ted Member ✭✭
    edited July 2019
    I meant to say FHM-2 ESSB Profile
  • Steve K9ZW
    edited July 2019
    Here is the thread confirming FHM-3 is only a stock number change from FHM-2 microphones. https://community.flexradio.com/flexradio/topics/what-profile-setting-do-i-use-for-a-microphone-that-is-not-listed-in-the-profile-settings-list 73 Steve K9ZW Blog: http://K9ZW.wordpress.com
  • KF4HR
    KF4HR Member ✭✭
    edited July 2019
    Probably just an issue of the people dealing with ordering the hardware, missed mentioning the model number change to the SSDR programmers.
  • Larry _ NY8T
    Larry _ NY8T Member ✭✭✭
    I see FHM-2 and FHM-3 mic profiles in my list.
  • Brian Denley  KB1VBF
    edited July 2019
    Not on mine. Wonder why I am using latest smartsdr.
    edited July 2019
  • Larry _ NY8T
    edited July 2019
    Let me know which  one you want to use and I will give you the EQ Settings.
    edited July 2019
    Thanks Larry!
  • Larry _ NY8T
    edited July 2019
    I can give you the EQ settings if you let me know which you want to use.
  • Larry _ NY8T
    edited July 2019
    Actually I just compared the EQ settings for FHM-2 and its the same as the FHM-3.
    edited July 2019
    Then I am all set. Thanks!
