Wireless Remote Switching
Just setting up another remote switch - very cheap and very easy to do, so I thought I would share the information
I am using these and they proved to be really useful and reliable.
Manufactured by Sonoff - this is the 4 way device out of their range of products.
https://sonoff.itead.cc/en/products/sonoff/sonoff-4ch-pro
Sells around £20 $25
1 Operate from your phone/Ipad/Android remote device
2 Has 4 X 10A change over relays
3 Powered from DC or line voltage
4 Operation can be individual or interlocked
5 WiFi into your home network
6 Custom label the functions on remote device
Setup time - a few minutes !
I use to remote my 6400
I power up the 12V supply - remote switch on the transceiver - remote ON the antenna isolation - remote change over 1 of 2 antennas
Just add more devices if you need more switches
If you need remote switches - and cheap - give them a try
Available from all the usual online sources.
73 Phil G4UDU
73 Phil G4UDU
Hi Phil, do you know if the connection to the controller uses a secure access like VPN? I built my own remote switch using a PI as this was the most secure way to access my controller using Real VPN as the link. But this unit is so much simpler.0
Sonoff using the EWE Link app is part of the "IT Lead" company based in China.
The app is I would think is using a connection path via their servers.
Personally I have 2 internet access setups - one high speed for my computers etc and the other a minimum cost ADSL account that is used to hang any "Odd Stuff" onto - I found that is an easy way.
If we have an IT Network expert who can check out the company they may want to comment ........
Phil G4UDU
Another source is Robot Electronics (UK), https://robot-electronics.co.uk/products.html?p=2. They make internet-controllable units with 4, 8, and 24 relays.0
Too expensive.0
Phil, ordered two from Amazon. What's the name of the app for iPhone?0
The APP is eWeLink.,, I dont use it, I was checking these out after Phil talked about them...0
Non Chinese. Backdoors, anyone?0
EWeLink is the App for iPhone/Ipad0
Thanks for the info. I use an Amazon smart switch and contacts from a 115V relay to remotely switch on/off the FLEX.
However, one of my main antennas in the small lot I have is a Hi Q screwdriver antenna on a large aluminum patio over. I need the ability to remotely hit an up/down 12 volt signal to tune the antenna. This might be adaptable to do that job!
Wayne W5GIE0
- 652 The Flea Market
- 384 SmartSDR API
- 50 Aurora
- 966 Maestro
- 938 Genius Products
