Spot screen Maestro
Jean Drolet
Already suggested putting the screen off when the Maestro is not used.
Tom said there is no problem that the screen is made for that.
But today i have many spot on my screen
if I send it for repair that will pay. Sorry for English I'm French
There is no screen saver function?0
Those brown areas on the bottom look like burn marks
Parts to repair the Dell tablet on order. 1 battery and 1 screen.
yes it's a Dell tablet venue 8 pro inside.
I have the same problem. It just started doing this.
Did you do this as your idea, or did Flex advise you?0
I repair without going through flexradio1
In last picture is it showing that the Battery swelled? 73 Steve K9ZW0
I would send it in right away. If you try to fix it yourself you may void any warranty
From Jean's pictures it looks like the tablet is expanding0 -
after 3 years there is no warranty0
I have initiated a helpdesk ticket. We'll see what they advise. I assume my warranty is long gone.0
Jean, is the battery swollen or leaking?
the battery is swollen and the screen seems burned at 3 place at the bottom0
If it's a battery issue you might not want to leave it on unattended
the tablet is disassembled and the pieces are on order
That sounds very bad
All part in order and old part in the garbage0
Had this happen to a phone that I would leave charging most of the time....repair shop said same thing as below and that it was a fire risk in addition to the excessive heat resulting in damage to the device.
Regards, Al / NN4ZZ
al (at) nn4zz (dot) com
I think about the same age. I really don't remember, but I got them when they first were available.0
I was just wondering if it was the age causing it. if it is then you should be able to find other comments about that table on the internet0
The age just after 3 years0
New screen , new battery install in 15 minute
Does this mean that the M should not be plugged in the whole time. If we leave the M unplugged long enough, the internal battery will discharge to the point where the M's charging circuit won't recharge it.
I've been leaving my M plugged in to it's power supply 24/7. I use it several times a week. I rarely move it away from the operating desk, I use it more like a desktop radio. Should I adopt some procedure of unplugging the power supply?
My M is one of the first ones made.
Mark
Mark, how many reports have we seen with this happening? For me I think it is the only one I have heard about.0
Was the screen purchased from Flex Radio? If not where did you purchase it? Thanks0
- 636 The Flea Market
- 143 SmartSDR+
- 261 SmartSDR CAT
- 199 DAX
- 45 Aurora
- 957 Maestro
- 57 FlexControl
- 931 Genius Products
- 302 Shack Infrastructure
- 141 Amateur Radio Interests
