RTTY with N1MM
WP3C
Hi
I’m setting up N1MM to work NAQP RTTY contest but need some help. If I put the Flex in LSB mode I have RX but not TX and if put RTTY, I get TX but not RX. I don’t know which is the correct mode to put on the flex, if LSB or RTTY. Any help will be well appreciated. Thanks0
The correct mode is RTTY, for sure. Be certain your filters are not eliminating the RTTY signals. Are you using MMTTY?
John W9ILY
Hi
Yes I use MMTTY. but thanks, I already fixed it and it was the filters. 73'0 -
Alfredo.. you should not be using LSB as the mode, but the mode "RTTY" selectable from the mode menu. I am glad you got your filters fixed, this can be confusing, especially if you change your mark from 2125 to say 915 you have to adjust your TX filter to accommodate that.
- 391 Community Topics
- 665 The Flea Market
- 167 SmartSDR+
- 446 SmartSDR for Mac
- 209 DAX
- 387 SmartSDR API
- 65 Aurora
- 307 FLEX-8000 Signature Series
- 978 Maestro
- 868 FLEX Series (Legacy) Radios
- 951 Genius Products
- 348 Tuner Genius XL
- 129 Antenna Genius
- 309 Shack Infrastructure
- 216 Networking
- 828 Peripherals & Station Integration
- 145 Amateur Radio Interests
