RTTY with N1MM
WP3C
WP3C Member ✭✭
Hi
I’m setting up N1MM to work NAQP RTTY contest but need some help. If I put the Flex in LSB mode I have RX but not TX and if put RTTY, I get TX but not RX. I don’t know which is the correct mode to put on the flex, if LSB or RTTY. Any help will be well appreciated. Thanks
  • W9ILY
    W9ILY Member ✭✭
    edited July 2019
    The correct mode is RTTY, for sure. Be certain your filters are not eliminating the RTTY signals. Are you using MMTTY?
    John W9ILY
  • WP3C
    WP3C Member ✭✭
    edited July 2019
    Hi
    Yes I use MMTTY. but thanks, I already fixed it and it was the filters. 73'
  • ctate243
    ctate243 Member ✭✭
    edited July 2019
    Alfredo.. you should not be using LSB as the mode, but the mode "RTTY" selectable from the mode menu.  I am glad you got your filters fixed, this can be confusing, especially if you change your mark from 2125 to say 915 you have to adjust your TX filter to accommodate that.
