RTTY with N1MM
WP3C
Hi
I’m setting up N1MM to work NAQP RTTY contest but need some help. If I put the Flex in LSB mode I have RX but not TX and if put RTTY, I get TX but not RX. I don’t know which is the correct mode to put on the flex, if LSB or RTTY. Any help will be well appreciated. Thanks0
The correct mode is RTTY, for sure. Be certain your filters are not eliminating the RTTY signals. Are you using MMTTY?
John W9ILY
Hi
Yes I use MMTTY. but thanks, I already fixed it and it was the filters. 73'0 -
Alfredo.. you should not be using LSB as the mode, but the mode "RTTY" selectable from the mode menu. I am glad you got your filters fixed, this can be confusing, especially if you change your mark from 2125 to say 915 you have to adjust your TX filter to accommodate that.
- 389 Community Topics
- 53 Aurora
- 971 Maestro
- 945 Genius Products
- 307 Shack Infrastructure
