6400 has low transmit power
Robert Nobis
Hi! My 6400 has very low RF output (under 1 watt in Tx mode), even with TX controls at full power. I just updated to SmartSDR 3.0.27. This is happening when operating with the latest version of WSJT-X, v2.1.0.
I went through the process of doing a hard reset of my 6400, and no change.
Attached a a few screen shots of my setup. I am obviously overlooking something.
Any assistance would be greatly appreciated.
Bob - N7RJN
Bob - N7RJN
Hi Robert
In you DAX screen shot, is that while in Transmit at there is no audio in the TX stream. You also don't seem to decoding anything.
You didn't show your WSJTx Audio Settings panel. Can you show a screen shot of that?
Mike1 -
Also, the DAX button is not selected. It's gray not blue.2
maybe im missing something...but the dax is not blue on the mic control on the screen shot right hand side of pan under acc+
Hi Mike,
No the DAX screen shot was not during transmit. Attached is a screen shot of the WSJT-X Audio Panel.
Bob
Yes, it is gray. Not sure how to select it to make it blue?
No you did not miss that. It was grayed out. I have now selected DAX on MIC control.1
Decoding occurs, however it is sporadic. It doesn't happen on every cycle.0
The screen shot "App Volume and Device Preferences" is a Windows system setting. You must NOT have any DAX devices selected as Windows system devices. This will normally produce an error message. Choose speakers and a system mic for these settings, but never any Flex devices.
Thank you. After selecting DAX in MIC Control I can now transmit. Thank you.
Here is a screen shot during transmission.
Now I need to resolve the issue of not decoding on every cycle. Thought maybe it was my clock being off, but it is accurate to about 20 milliseconds.
73, Bob0 -
Hi Craig,
Thank you. I made this change to the Windows sound settings, but it does not seem to make any difference in operation.
73, Bob
I get no decodes sometimes and after restarting both WSJT & Smartsdr it starts working again. Something to do with DAX I think ? Does this with my Win7 & Win10 PC's
Good luck ! Vidas0 -
The 200ms timing difference is fine.
I talked to Joe Taylor about how critical Time is and you can be +/- 2.5 seconds. So, it isn't critical.
After you get everything set up, I would suggest saving a separate Mic Profile as “WSJT” or “DigU” and then associate it with the DigU mode ... that way you won’t need to remember to change parameters whenever you change from USB to DigU and back. For DigU, I would also set the TX bandwidth from 0-3000Hz, in order to utilize the full audio bandwidth of the digital sub-band. Ken - NM9P1
I also see TUNE, MOX as well as ATU and MEM all greyed out in the TX panel.. that indicates to me like the radio thinks it's outside it's allowed transmitting frequency range...
What does your Region show under "Settings" and then "Radio Setup"
Another thought... did you upgrade the Radio recently? if so did you do a factory reset after that upgrade.
I'm also noticing you have an issue with the PC audio.. can you supply a screen shot of Device manager / Audio inputs and outputs?1 -
On your WSJT-x receive screen, your receive level seems a bit high. I usually run the DAX RX level slider lower than 100 and keep the quiet band WSJT level between 20-30 to give it some headroom. If the WSJT RX level is much over 80, and especially if it exceeds the top, I get decoding dropouts. My own settings on WSJT modes runs the Flex AGC-T OFF, with the Dax RX level slider at 50, then I use the manual AGC setting to set the WSJT meter at about 20 when the channel is clear, and bump it down just a little if a really strong signal drives it over 80. Then I leave it alone. It requires my local speaker volume to be reduced, but I seem to get really good RX dynamic range this way on digi modes. It is a little more work this way.....YMMV. Ken - NM9P1
Mike,
+/- 2.5 seconds seems like quite a bit of tolerance, especially for FT8 with it's 15 second cycle. But, yes I have decoded transmissions that were over 2 seconds off.
Thank you and 73,
Bob - N7RJN
Hi David,
My region shows "USA".
Yes, I did upgrade to SmartSDR 3.0.27. And yes, I did a complete factory reset after this.
I am not at my rig now, but will provide a screen shot of Device Manager a bit later.
Thanks and 73,
Bob - N7RJN
I checked with the guy who wrote the code to be sure.
This means you can easily hand sync a PC by watching other signals, or listening to WWV.
Mike1 -
Hi Ken,
I will look at the DAX RX Level a bit later and let you know, as I am not in my shack right now. This might explain my decoding drop outs.
I will also check out your suggestions on manual adjustment of the AGC.
I did do one additional thing before I went to bed last night. I am operating Windows 10 on a Mac under VMware Fusion. I assigned some additional resources to VMware. Since there was very little band activity after midnight, I couldn't verify if this improved decoding. I will watch this today.
Thanks and 73,
Bob - N7RJN
It appears I am not the only one seeing issues with decoding of FT8 signals occasionally stopping. There is a thread on the WSJTX@groups.io page titled: "Another case of decoding stopping..." It would appear the problem may possibly be because of a recent Windows10 upgrade that resulted in some issues with the drivers used by DAX. I will be following the groups.io thread to see how this shakes out.
Bob - N7RJN0
- 335 Community Topics
- 602 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 400 SmartSDR for Mac
- 263 SmartSDR for iOS
- 247 SmartSDR CAT
- 184 DAX
- 371 SmartSDR API
- 9.1K Radios and Accessories
- 17 Aurora
- 181 FLEX-8000 Signature Series
- 913 Maestro
- 882 Genius Products
- 319 Tuner Genius XL
- 116 Antenna Genius
- 280 Shack Infrastructure
- 196 Networking
- 137 Contesting
- 736 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 950 Third-Party Software
