BP filter and Ultrabeam/StepIR antenna
Tore Andersson
I am wondering how you guys that are using StepIR or Ultrabeam antennas that you set dynamically on frequency that you use, have solved your BP filtering ? How do you switch in the correct filter when you are running it on a specific band?
I plan to connect my Ultrabeam to Ant1 of the 6600 and the Ant2 will connected to my current filtering system used with a TH11.
73's de Tore
73's de Tore
Hi Tore
You may wish to review the USB Document on the web site. You will find it will give you a lot of good ideas.
https://www.flexradio.com/downloads/usb-cable-interface-guide-pdf/
Mike va3mw
- 394 Community Topics
- 670 The Flea Market
- 177 SmartSDR+
- 453 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 80 Aurora
- 982 Maestro
- 954 Genius Products
- 350 Tuner Genius XL
- 130 Antenna Genius
- 312 Shack Infrastructure
- 218 Networking
- 146 Amateur Radio Interests
