green light in flex radio
Mike-N1VE
When the Flex 6400 is turned off but connected to 12-volts, if I look just right, along the side of the radio, I can see a small green light inside. Can anyone tell me what the light indicates and if it is best to turn off the power supply when not using the radio.
The answer also affects me. I also noticed the light but I turn off the power ... am I wrong?
There are several LEDs on the board as indicators for diagnosis. It is fine to leave the radio powered down with a supply attached.0
My question was about leaving the power supply on. Since when the power supply is attached to the radio and when the radio is off, the light(s) continue to glow. Is there a longevity problem for the radio when leaving the power supply running when the radio is not running?0
I clarified my previous post, but there shouldn't be a problem leaving the radio powered off while the supply is connected (and powered). Note that there are several schools of thought with regard to whether you should turn your radio/supply off when you aren't using it. Similar to the same discussion about whether to power down your computer. The good news is that your radio (and your computer) should be fine either way.0
Eric, thank you for your answer to my question. Is a fan or are there fans operating whenever the radio is turned on? If so, I would be reluctant to leave it running unless in use, because I wouldn't want to draw dust into the radio cabinet.0
There is indeed a fan that is on when the radio is on.0
Question: Does the radio’s master references clock (non GPSDO) remain on with radio powered down? This is usually the main reason to keep a radio powered on.0
No. Those clocks are powered down when in standby.0
- 371 Community Topics
- 94 SmartSDR+
- 424 SmartSDR for Mac
- 270 SmartSDR for iOS
- 937 Maestro
- 54 FlexControl
- 996 Third-Party Software
