FlexRadio 6300 XVTR power increase greater 15 dBm
DL7MST
Hello Om´s
does someone know to increase the XVTR Power out greater than 15dBm limit?
For an Transverter operation i need at least 20-30 dBm.
Otherwise i have to use the 2nd Antenna out....
any ideas?
vy73, DL7MST,Matthias
any ideas?
Hi Matthias
The maximum RF out of the XVTR port is actually 10dbm and there is no way to increase it inside the radio.
Which transverter are you using?
73, Mike0 -
Hi Michael,
thank you, i might have known it.
I use the Ukraine Transverter from Transverter Store, for 144 MHz
73, Matthias0 -
The Ukraine Transverters used to only ship with attenuators, he now offers them assembled without attenuators boards as well as with them. For example, here is the pre-built, ready-to-use 2m transverter without attenuator on eBay: https://www.ebay.com/itm/144-to-28-MHz-ASSEMBLED-TRANSVERTER-WITHOUT-ATTENUATOR-2m-144mhz-146mhz-VHF-UHF-/222662833996 He also used to provide instruction on request in how to bypass the attenuators. Hope this helps0
Agree - i used one for a while without an attenuator. The Flex handled it well.0
I have one without the attenuator, but only drive it with about 10% of the transverter port available power. You don’t want to run the transverter at full output anyway, reports are that they start to get dirty at more than about two Watts output.0
- 328 Community Topics
- 593 The Flea Market
- 7.8K Software
- 6.2K SmartSDR for Windows
- 396 SmartSDR for Mac
- 260 SmartSDR for iOS
- 246 SmartSDR CAT
- 179 DAX
- 369 SmartSDR API
- 9.1K Radios and Accessories
- 15 Aurora
- 160 FLEX-8000 Signature Series
- 909 Maestro
- 51 FlexControl
- 873 Genius Products
- 312 Tuner Genius XL
- 115 Antenna Genius
- 278 Shack Infrastructure
- 196 Networking
- 438 Remote Operation (SmartLink)
- 135 Contesting
- 722 Peripherals & Station Integration
- 136 Amateur Radio Interests
- 942 Third-Party Software
