FlexRadio 6300 XVTR power increase greater 15 dBm
DL7MST
Hello Om´s
does someone know to increase the XVTR Power out greater than 15dBm limit?
For an Transverter operation i need at least 20-30 dBm.
Otherwise i have to use the 2nd Antenna out....
any ideas?
vy73, DL7MST,Matthias
any ideas?
Hi Matthias
The maximum RF out of the XVTR port is actually 10dbm and there is no way to increase it inside the radio.
Which transverter are you using?
73, Mike0 -
Hi Michael,
thank you, i might have known it.
I use the Ukraine Transverter from Transverter Store, for 144 MHz
73, Matthias0 -
The Ukraine Transverters used to only ship with attenuators, he now offers them assembled without attenuators boards as well as with them. For example, here is the pre-built, ready-to-use 2m transverter without attenuator on eBay: https://www.ebay.com/itm/144-to-28-MHz-ASSEMBLED-TRANSVERTER-WITHOUT-ATTENUATOR-2m-144mhz-146mhz-VHF-UHF-/222662833996 He also used to provide instruction on request in how to bypass the attenuators. Hope this helps0
Agree - i used one for a while without an attenuator. The Flex handled it well.0
I have one without the attenuator, but only drive it with about 10% of the transverter port available power. You don’t want to run the transverter at full output anyway, reports are that they start to get dirty at more than about two Watts output.0
- 371 Community Topics
- 93 SmartSDR+
- 424 SmartSDR for Mac
- 270 SmartSDR for iOS
- 35 Aurora
- 246 FLEX-8000 Signature Series
- 937 Maestro
- 54 FlexControl
- 451 Remote Operation (SmartLink)
- 996 Third-Party Software
