Multiflex setup? Are there options
Wayne W5GIE
I presume that the latest version of SSDR is the one that FlexRadio will keep updated, so I'm using v 3.0.27
The radio and amplifier are in a spare room because of easy access to antenna feedlines. I do operate from that position at times. Mostly, I operate via SSDR from a desktop in my office.
Thus, I will operate from the radio or from the office, but never, ever from both at the same time.
With multiflex, I often get strange situations where my operating position keys the wrong operating position. (perhaps on the wrong frequency) Or the audio goes to the wrong position.
Are there settings such that I can essentially disable the multiflex feature?
Wayne W5GIE
Wayne W5GIE
You can load 2.5.1 That has the fixes rolled in to 3.0.27. You can also create separate profiles for each position which will have rx audio and mic selections set up for each. Dave wo2x1
Good info, Dave. I'll have to give 2.5.1 a try. First, I'll try to learn more about multiflex, as the info will likely be useful in contest operations at other ham stations.
Wayne W5GIE0 -
not to high jack the topic but, i use ios app on iphone, i assume i would need to make a mic profile for the iphone and save it, and that would be done from iphone?0
Once you connect with the IOS app it should create a iOS_Default_Profile. Use that (second tab on bottom of IOS app and scroll down to the profiles section. Find the IOS_Default_Profile and select it and tap Use. That should load the IOs_Default TX and mic profiles. Don’t forget to change the mic to iPhone or iPad. Dave wo2x1
- 391 Community Topics
- 665 The Flea Market
- 167 SmartSDR+
- 446 SmartSDR for Mac
- 209 DAX
- 387 SmartSDR API
- 65 Aurora
- 307 FLEX-8000 Signature Series
- 978 Maestro
- 868 FLEX Series (Legacy) Radios
- 951 Genius Products
- 348 Tuner Genius XL
- 129 Antenna Genius
- 309 Shack Infrastructure
- 216 Networking
- 828 Peripherals & Station Integration
- 145 Amateur Radio Interests
