Dax Rx gain
DonE
DonE Member ✭✭
edited December 2019 in FLEX-6000 Signature Series
Why does my DAX Rx gain not work when i first cut the 6400 on until i click on it and move the slider? I am running v2.5.1 and did not have this problem before.
  • Gary NC3Z
    Gary NC3Z Member ✭✭✭
    edited July 2019
    Sort of the same here with 3.0.27. The levels are not correct when first starting and you must just tweak the sliders to get the levels to kick in to where they should be.
  • Wim
    Wim Member ✭✭
    edited July 2019
    same here, I have to toggle the DAX gain sliders one down one up and then the level on WSJTX drops 20dB back to normal, each time I wake up the computer from sleep mode ...
  • Gary NC3Z
    edited July 2019
    It has been an issue for a long time, just a fact of life and I just try to remember to do this each and every time I start DAX. I know it's not a good answer but I don't see this being fixed for a long time to come.
  • Bill -VA3WTB
    Bill -VA3WTB Member ✭✭✭
    edited July 2019
    I wonder if this is on the bug tracker list?
  • Michael N3LI
    Michael N3LI Member ✭✭
    edited July 2019
    I'm trying to duplicate this on my radio. (6600 and latest version 3) Does the problem present when using WSJT or all times?
  • Gary NC3Z
    edited July 2019
    No it has nothing to do with the program being used.
  • Eric-KE5DTO
    edited July 2019
    We are aware of this issue (#7578) and are working on a fix.  Thanks for bringing this to our attention!
  • DonE
    DonE Member ✭✭
    edited July 2019
    Thanks for letting us know.
  • Jeff_W4DD
    Jeff_W4DD Member ✭✭
    edited July 2019
    FYI, occurs when first powering up the radio or if your change bands.  DAX RX is too high.  If you move the slider by 1 unit (aka 24 to 23) audio level then corresponds to slider position
  • James Skala
    James Skala Member
    Just found the issue as well.  Ugg I'm slow!  I'm running 3.1.8
