Dax Rx gain
DonE
Why does my DAX Rx gain not work when i first cut the 6400 on until i click on it and move the slider? I am running v2.5.1 and did not have this problem before.
Sort of the same here with 3.0.27. The levels are not correct when first starting and you must just tweak the sliders to get the levels to kick in to where they should be.0
same here, I have to toggle the DAX gain sliders one down one up and then the level on WSJTX drops 20dB back to normal, each time I wake up the computer from sleep mode ...0
It has been an issue for a long time, just a fact of life and I just try to remember to do this each and every time I start DAX. I know it's not a good answer but I don't see this being fixed for a long time to come.0
I wonder if this is on the bug tracker list?0
I'm trying to duplicate this on my radio. (6600 and latest version 3) Does the problem present when using WSJT or all times?0
No it has nothing to do with the program being used.0
We are aware of this issue (#7578) and are working on a fix. Thanks for bringing this to our attention!1
Thanks for letting us know.0
FYI, occurs when first powering up the radio or if your change bands. DAX RX is too high. If you move the slider by 1 unit (aka 24 to 23) audio level then corresponds to slider position0
Just found the issue as well. Ugg I'm slow! I'm running 3.1.80
- 694 The Flea Market
