Spot screen Maestro
edited June 2020 in Maestro
 Already suggested putting the screen off when the Maestro is not used.
 Tom said there is no problem that the screen is made for that.
But today i have many spot on my screen
if I send it for repair that will pay. Sorry for English I'm French
Welcome!
«13
  • Member ✭✭
    edited June 2019
  • Member ✭✭
    edited August 2019
  • Member ✭✭
    edited November 2019
    There is no screen saver function?
  • Member ✭✭
    edited June 2019
    Those brown areas on the bottom look like burn marks
  • Member ✭✭
    edited July 2019
    Parts to repair the Dell tablet on order. 1 battery and 1 screen.
    yes it's a Dell tablet venue 8 pro inside.imageimage
  • Member ✭✭
    edited July 2019
    I have the same problem.  It just started doing this.image
  • Member ✭✭
    edited July 2019
    Did you do this as your idea, or did Flex advise you?
  • Member ✭✭
    edited July 2019
    I repair without going through flexradio
  • Member ✭✭✭
    edited July 2019
    In last picture is it showing that the Battery swelled? 73 Steve K9ZW
  • Member ✭✭
    edited July 2019
    I would send it in right away. If you try to fix it yourself you may void any warranty
    From Jean's pictures it looks like the tablet is expanding
  • Member ✭✭
    edited July 2019
    after 3 years there is no warranty
  • Member ✭✭
    edited July 2019
    I have initiated a helpdesk ticket.  We'll see what they advise.   I assume my warranty is long gone.
  • Member ✭✭
    edited July 2019
    Jean, is the battery swollen or leaking?
  • Member ✭✭
    edited July 2019
    the battery is swollen and the screen seems burned at 3 place at the bottom
  • Member ✭✭
    edited July 2019
    If it's a battery issue you might not want to leave it on unattended
  • Member ✭✭
    edited July 2019
    the tablet is disassembled and the pieces are on order ;)
  • Member ✭✭
    edited July 2019
    That sounds very bad
  • Member ✭✭
    edited July 2019
    All part in order and old part in the garbage
  • Member ✭✭
    edited July 2019
    @Mike - just wondering if the battery is swelling like in Jean's case how would you ship it to Flex? Wouldn't that be unwise?
  • Member ✭✭✭
    edited February 2020
    Had this happen to a phone that I would leave charging most of the time....repair shop said same thing as below and that it was a fire risk in addition to the excessive heat resulting in damage to the device.
    Regards, Al / NN4ZZ
    al (at) nn4zz (dot) com
  • Member ✭✭
    edited July 2019
    @Mike, how old is your Maestro? Jean says his is 3 years old.
  • Member ✭✭
    edited July 2019
  • Member ✭✭
    edited July 2019
    I think about the same age.  I really don't remember, but I got them when they first were available.
  • Member ✭✭
    edited July 2019
    I was just wondering if it was the age causing it. if it is then you should be able to find other comments about that table on the internet
  • Member ✭✭
    edited July 2019
    The age just after 3 years
  • Member ✭✭
    edited August 2019
    New screen , new battery install in 15 minuteimage
  • Member ✭✭
    edited August 2019
  • Member ✭✭
    edited July 2019
    Does this mean that the M should not be plugged in the whole time. If we leave the M unplugged long enough, the internal battery will discharge to the point where the M's charging circuit won't recharge it.
    I've been leaving my M plugged in to it's power supply 24/7. I use it several times a week. I rarely move it away from the operating desk, I use it more like a desktop radio. Should I adopt some procedure of unplugging the power supply?
    My M is one of the first ones made.
    Mark
  • Member ✭✭✭
    edited July 2019
    Mark, how many reports have we seen with this happening? For me I think it is the only one I have heard about.
  • Member ✭✭
    edited June 2020
    Was the screen purchased from Flex Radio? If not where did you purchase it? Thanks
