FLEX6600M AND PGXL Setup Any Help
mikeatthebeach .
Setup help needed
Just got PGXL
Just got PGXL
Remember maybe it was NH7Q Dan had info somewhere on the forum
It's like plug and play. Use the quick start handout. Plug both the transceiver and the PG into your Network. Only other connection is transceiver to radio a or b and antenna to the same output as the transceiver a or b. Really very easy.0
Need to download PGXL Utility and configure several panels:
https://community.flexradio.com/flexradio/topics/pgxl-windows-utility-quick-reference-graphic
Bill Thanks, this was the Info I was looking for Mike0
have my 80 and 40 Meter Antenna 1 And Have 20 thru 6 Meter As Antenna 2 Using Flex6600 In the PGXL Utility Assume I need to enter SN# twice One as Port A for Antenna 1 and Again for Antenna 2 for Port B Is that a Correct?0
correct. Depending on your antenna separation, you may need isolation filters if you intend on operating full duplex.. give it a shot and see how it works.0
Got a Problem with PGXL Utility Program See no Available Devices even though Both Flex6600M and PGXL Plug into Ethernet HUB (see below) All hub Light Blink All Ethernet Ports talking, PC, 6600M Not sure about the PGXL Ethernet is working ! Can not configure past setup Connect does respond DOA Maybe bad Network Card in PGXL Tried different CAT cables Still the same Can not get the PGXL Configuration Menu to come up to set SN# Just stays stuck PGXL Utility Program Can not get past Continue Any help Maybe I got a Bad PGXL with a bad Ethernet Port Followed the StartUp Instructions With the PGXL Just got this Today and not looking Good Have TeamViewer Here
OK Working Now Had to Repower PGXL a few times To get PGXL Utility to kick in Think I am am my way to use the PGXL Mike0
Glad to hear you got things working Mike. Keep us posted on how it works for you.
Yes, works great Only wish it had a Fan Quiet Mode day for Pout less than 500Watts or Temps lower than 40deg C Mike0
- 379 Community Topics
- 631 The Flea Market
- 123 SmartSDR+
- 193 DAX
- 39 Aurora
- 948 Maestro
- 925 Genius Products
- 337 Tuner Genius XL
