Windows 10 alert FYI
Michael N3LI
For those using Windows 10, and who like to have their registry backed up, be aware that Microsoft turned off registry backups. And in true strange fashion it will look like it did, the backup will run, but each registry hive will be 0 kBytes in size.
Microsoft recommends you use system restore if your registry becomes corrupted. So for the last 8 months, this has been the case
You can't alert others to the problem without also informing them how to correct the situation, should they choose to. This issue was detected back in October, 2018, but only recently has MS admitted it, provided a justification for it (save space), and shared a method to restore the registry backups. I'd encourage anyone interested to refer to this article for information on how to re-enable windows registry backups: https://www.ghacks.net/2019/06/29/microsoft-explains-the-lack-of-registry-backups-in-windows-10/3
Or re-image regularly + before each scheduled major update.
I've always been a little hesitant to tell people about digging into the registry when I don't know their level of expertise. That is the voice of experience talking.0
Sure - There are also third party backup programs. I told a fellow how to makes some changes in his registry once. Then he read about how it can mess up your system. After that it was amazing how I owned every problem on his computer. Hard drive or monitor failure? Must have been that registry hack!0
Ccleaner0
Clean my PC is also a good registry maintaining tool. Has other tools also.0
So this came with a "Up Date" I know some day I will be forced to "upgrade" but for now I do not have all these problems with Windoz 70
- 371 Community Topics
- 94 SmartSDR+
- 424 SmartSDR for Mac
- 270 SmartSDR for iOS
- 937 Maestro
- 54 FlexControl
- 996 Third-Party Software
