FLEX6600M AND PGXL Setup Any Help
edited July 2019 in SmartSDR for Windows
Setup help needed
Just got PGXL
Welcome!
  • Member ✭✭
    edited July 2019
    Remember maybe it was NH7Q Dan had info somewhere on the forum
  • edited July 2019
    It's like plug and play.  Use the quick start handout.  Plug both the transceiver and the PG into your Network.  Only other connection is transceiver to radio a or b and antenna to the same output as the transceiver a or b.  Really very easy.
  • Member ✭✭
    edited July 2019
  • Member ✭✭
    edited July 2019
    Bill Thanks, this was the Info I was looking for Mike
  • Member ✭✭
    edited July 2019
    have my 80 and 40 Meter Antenna 1 And Have 20 thru 6 Meter As Antenna 2 Using Flex6600 In the PGXL Utility Assume I need to enter SN# twice One as Port A for Antenna 1 and Again for Antenna 2 for Port B Is that a Correct?
  • Member ✭✭
    edited July 2019
    correct.  Depending on your antenna separation, you may need isolation filters if you intend on operating full duplex.. give it a shot and see how it works.
  • Member ✭✭
    edited July 2019
    Got a Problem with PGXL Utility Program See no Available Devices even though Both Flex6600M and PGXL Plug into Ethernet HUB (see below) All hub Light Blink All Ethernet Ports talking, PC, 6600M Not sure about the PGXL Ethernet is working ! Can not configure past setup Connect does respond DOA Maybe bad Network Card in PGXL Tried different CAT cables Still the same Can not get the PGXL Configuration Menu to come up to set SN# Just stays stuck PGXL Utility Program Can not get past Continue Any help Maybe I got a Bad PGXL with a bad Ethernet Port Followed the StartUp Instructions With the PGXL Just got this Today and not looking Good Have TeamViewer Here image
  • Member ✭✭
    edited July 2019
    OK Working Now Had to Repower PGXL a few times To get PGXL Utility to kick in Think I am am my way to use the PGXL Mike
  • Member ✭✭
    edited July 2019
    Glad to hear you got things working Mike.  Keep us posted on how it works for you.
  • Member ✭✭
    edited July 2019
    Yes, works great Only wish it had a Fan Quiet Mode day for Pout less than 500Watts or Temps lower than 40deg C Mike
