upgrading to 2.51 from 2.49
Dave Garber
Tried a couple of times to upgrade to 2.5.1, but ran into an issue ( not always immediate) where when changing profiles/bands from flex software, the other software would not follow the band change. but if I change bands from the 'other' software, the flex does follow any hints, maybe a timing issue?
Thank you!
Please post the response gents
TU.
What "Other software"?
other software includes wsjt-x, jtalert, and HRD, also could include n3fjp, all of which has cat control working just fine in 2.4.9 If I change frequencies in these, the radio will change, too. but not always the other way. hard to logg, and remember to check the cat every time
I use WSJT-X, JTAlert and HRD Logbook without issue. I can help you with settings. Maybe a TeamViewer session if you want. What do you use to interface HRD Logbook to Flex? Main HRD program? BTW, There is a new version of HRD which should be released this week. Dave wo2x0
- 650 The Flea Market
- 154 SmartSDR+
- 49 Aurora
- 964 Maestro
- 938 Genius Products
