upgrading to 2.51 from 2.49
Dave Garber
Dave Garber Member ✭✭
Tried a couple of times to upgrade to 2.5.1, but ran into an issue ( not always immediate) where when changing profiles/bands from flex software, the other software would not follow the band change. but if I change bands from the 'other' software, the flex does follow   any hints, maybe a timing issue?
  • Pat Eastman
    Pat Eastman Member ✭✭
    edited June 2019
    Thank you!
  • Clay N9IO
    Clay N9IO Member ✭✭✭
    edited August 2019
    Please post the response gents
    TU.
  • David Decoons, wo2x
    What "Other software"?
  • Dave Garber
    other software includes wsjt-x, jtalert, and HRD, also could include n3fjp, all of which has cat control working just fine in 2.4.9  If I change frequencies in these, the radio will change, too.  but not always the other way.    hard to logg, and remember to check the cat every time
    edited July 2019
    I use WSJT-X, JTAlert and HRD Logbook without issue. I can help you with settings. Maybe a TeamViewer session if you want. What do you use to interface HRD Logbook to Flex? Main HRD program? BTW, There is a new version of HRD which should be released this week. Dave wo2x
