What operating mode/emission is this
N4AB
I keep running across this Signal(???) that appears to pop up on a single frequency then evolve into multiple tones that spread across the spectrum. Just before the signal stops,
it starts to collapse back into the single frequency it started with. (but the signal stops before it gets back to the original frequency). Has this question been asked and does anyone know what the answer is?
It almost looks like a birdie from some piece of equipment nearby.0
How much time between when it starts to when it stops and does it start over again? Slow down the display rate?0
I get the same signals from my LED TV,. Although, you can't hear the signals, I can see them when I turn on the TV and goes away when it's off. This only happens once in a while depending on what channel the TV is on.. This is what it looks like to me on your waterfall. Keeping in mind that the Flex is very sensitive to picking up any local signal traces that may be coming to your radio locally. Sometimes it's there for a while then disappears after a while. It could even be a Led light bulb. I also notice that if I click on the WNB it usually takes it away.
Most likely a HVAC system electric motor turning on.
Spread spectrum, based o n a modulated signal.
Pat
Cal beat me to it. That looks near identical to what I see when my HVAC turns on. Normally only seen on 15, 12, and 10m.
That looks like the “fan” pattern generated by many variable speed motors on HVAC equipment. Or it could be generated by one of the new front load washing machines. I used to see it a lot on 160 Meters. I’m surprised you get it all the way up to 15 Meters! Perhaps my HVAC was a little older than some of the new ones....0
- 394 Community Topics
- 670 The Flea Market
- 177 SmartSDR+
- 453 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 80 Aurora
- 982 Maestro
- 954 Genius Products
- 350 Tuner Genius XL
- 130 Antenna Genius
- 312 Shack Infrastructure
- 218 Networking
- 146 Amateur Radio Interests
