No Audio with N1MM RTTY Tx
W2ECK
Rebuilt my PC and have had to reinstall most programs. Having an issue when N1MM+ is in RTTY mode. Setup is Win 10 PC, v 3.0.27 SSDR, Flex 6600. When I press a function key in N1MM, the radio goes to TX, an seeing Tx signal in spectrum display and power out on Rf meter, but not hearing any audio or diddles. Have same problem if I run MMTTY without N1MM+ running. If I change to CW mode in N1MM+, I do hear audio when in TX. Anyone have any hints on how to restore audio while in RTTY.
73 & Tnx
Paul w2eck
73 & Tnx
Paul w2eck
Turn on the "MON" function. The button in on the "P/CW" control panel pane.
Gayle K0FLY0 -
Gayle - thanks for help, that was the issue. I tried that yesterday with no success, but it sure works today. Thank you again.
73 Paul w2eck0
- 391 Community Topics
- 665 The Flea Market
- 167 SmartSDR+
- 446 SmartSDR for Mac
- 209 DAX
- 387 SmartSDR API
- 65 Aurora
- 307 FLEX-8000 Signature Series
- 978 Maestro
- 868 FLEX Series (Legacy) Radios
- 951 Genius Products
- 348 Tuner Genius XL
- 129 Antenna Genius
- 309 Shack Infrastructure
- 216 Networking
- 828 Peripherals & Station Integration
- 145 Amateur Radio Interests
