Maestro lost of cw keying to remote 6600
Pre-tested 6600 at the remote site, Maestro at home with paddle and N1MM logger using SmartCat and Smart DAX version 2.4.9:115.
Got up early for CWT and would not key Flex 6600 form F1-F6 keys, N1MM or paddle on Maestro. Cold rebooted Flex 2 or three times before all was well again.
Anyone have any key to what I can look for next time. The network was green/yellow 90-100 MS Latency and 30 out of 2,000,000 packets or 0.00% per Maestro display.
Maestro tuned fine and displayed fine. Keying would generate sidetone but not key transmitter.
Thanks, Russ K5OA
Thanks, Russ K5OA
I have had this problem twice. Working CW remotely with Maestro and rig went key down (or so it appeared) and maestro display froze. Disconnected rig using SSDR on a computer (Disconnect user). After that no remote CW keying, although I had sidetone and tune worked. Could press MOX and go into tx but no keying still. In the first instance everything was located here and it fixed itself when I plugged the key directly into the rig, then reverted to maestro. This time rig is 1,255 miles up the road. What to do?0
- 379 Community Topics
- 631 The Flea Market
- 123 SmartSDR+
- 194 DAX
- 39 Aurora
- 950 Maestro
- 925 Genius Products
- 337 Tuner Genius XL
