Why can't you create a new com port? With Smart SDRCat
Piero Ferrua
why can't you create a new com port? remote station PC laptop + Maestro
I need to create a com port to use with the DM780 winkeyer (HRD siute) from the remote station.
The remote station has a laptop PC + Maestro; at the base a Flex 6600, all with the latest sofwere version.
Creating a new com with Smart SDR Cat the PC tells me this error:
Can someone help me?
Thanks in advance
Thanks in advance
SmartSDR CAT is designed to be able to create multiple ports. See the SmartSDR CAT User Guide for more info.0
Yes of course..... But only in my house PC. The picture in my post you can look the error information, why this?
Look to see if you have ghosted serial ports. You might be trying to set up COM27, and it's already assigned.1
Thank you very much Michael, I think the problem is just that.
I tried deleting everything and reinstating Smart SDR V3.0.27 but got no results.
The problem remains the same, can it be due to the PC (windows 7 - 32)?
The smart SDR CAT generates the ports, in fact the numbering increases with each attempt, but does not let me use them.
Device Manager -> check under view "show hidden devices" -> look under "ports (COM&LPT)
Show us what is there...
Thanks David,
on the Device Manager I see the com ports created, for every attempt with SmartSDR COM 2 VPCs are created with different numbers (example COM16 and COM116).
Therefore they are present in the system but cannot be used by Smart SDRCom!
Extreme decision ..... PC reset and Windows 7 reinstal !!!
On a table of new wax one writes better HIHI
Tomorrow I will be able to give news about it, thanks again best 73
IZ1XEE
If your problem is that you have ghost ports i.e. assigned ports not in use, you can free these up: https://helpdesk.flexradio.com/hc/en-us/articles/115000504463-Removing-In-Use-Com-Ports-for-Availabl...
The program discussed (https://www.uwe-sieber.de/misc_tools_e.html#arbiter) is excellent and I have used this on my Win7 computer to clean out unused ports. Reinstalling OS is a lot more work! Just make sure you run it as "Administrator"
As mentioned.. no reinstall necessary... simply select the ones that are grayed out, right mouse click.. a window will pop, select "uninstall device" but DO NOT remove the drivers.. so in your case you'd remove both com27 and it's pair com127... while your there you might as well remove any / all unused com ports. When you are finished reboot the PC and try again.
Good luck0 -
I have the exact problem. I removed all the unused, grayed out, ports. I ran the program that removes the unused ports from the registry. Rebooted and still cannot create a comport.
Anybody else have any ideas what to try?
Harold
W5ZZT
Thanks to everyone who wanted to help me with this problem.
By resetting the PC and windows, everything went well; SmartCAT works beautifully!
I exactly same message like shown in pictures , now can't create new ports I try programs to clear an use didn't make any difference, any suggestion
Rig is 6400 program SDR version 3.18 windows 100
- 633 The Flea Market
- 131 SmartSDR+
- 197 DAX
- 42 Aurora
- 955 Maestro
