picture post suggestion
dlwarnberg
Posting picture in the form I've noticed is all over the place, some seem to be taking pics with a phone...
Anyway there is a very simple program in windows that I use that works very cleanly.. it's called "snipit"
Simply open whatever it is you want to post about, open snipit, select "new", you will get a set of cross hairs to "snip" whatever in the box you create.. the snip will then show up, you can leave it as is, circle part of your snip, once you are happy with what you have then simply save it ..
in your post now just select the camera and drag your saved file to the box area.
It works really well.. this is however just for windows
hope this helps someone out there as pictures really help
Even easier, press Alt-PrintScreen. This takes a snapshot of the current window and saves it to the clipboard.
That works as well... the advantage of snipit is you only grab what you want and you can highlight, edit on the fly..
I just use Print screen and edit in Paint, at least on the Windows side. I use Photoshop on my Mac with Grab to take the image.0
Integral to Windows is the Snipping Tool. No 3rd party software involved. Works a treat...1
If you use the “Windows key” and S key as a keyboard short cut to “Snipping Tool” , just a little quicker in Win10. Dudley WA5QPZ1
The “Windows key”, SHIFT, and S key as a keyboard short cut is even quicker.
K1ESE0 -
Thanks David and Dudley, this is the snipit I made. Dudley, your Win10 tip helped me find Snipit.
- 379 Community Topics
- 636 The Flea Market
- 141 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 44 Aurora
- 956 Maestro
- 57 FlexControl
- 931 Genius Products
- 301 Shack Infrastructure
- 793 Peripherals & Station Integration
