picture post suggestion
dlwarnberg
dlwarnberg Member ✭✭
edited March 2020 in New Ideas
Posting picture in the form I've noticed is all over the place, some seem to be taking pics with a phone...
Anyway there is a very simple program in windows that I use that works very cleanly.. it's called "snipit"
Simply open whatever it is you want to post about, open snipit, select "new", you will get a set of cross hairs to "snip" whatever in the box you create.. the snip will then show up, you can leave it as is, circle part of your snip, once you are happy with what you have then simply save it ..
in your post now just select the camera and drag your saved file to the box area.
It works really well.. this is however just for windows
hope this helps someone out there as pictures really help
1 votes
In Review · Last Updated
  • Craig_KØCF
    Craig_KØCF Member ✭✭✭
    edited June 2019
    Even easier, press Alt-PrintScreen. This takes a snapshot of the current window and saves it to the clipboard.
  • dlwarnberg
    edited June 2019
    That works as well... the advantage of snipit is you only grab what you want and you can highlight, edit on the fly..
  • Michael N3LI
    Michael N3LI Member ✭✭
    edited June 2019
    I just use Print screen and edit in Paint, at least on the Windows side. I use Photoshop on my Mac with Grab to take the image.
  • Geoff AB6BT
    Geoff AB6BT Member ✭✭✭
    edited June 2019
    Integral to Windows is the Snipping Tool. No 3rd party software involved. Works a treat...
  • Dudley  WA5QPZ
    Dudley WA5QPZ Member ✭✭✭
    edited March 2020
    If you use the “Windows key” and S key as a keyboard short cut to “Snipping Tool” , just a little quicker in Win10. Dudley WA5QPZ
  • K1ESE
    K1ESE Member ✭✭✭
    edited June 2019
    The “Windows key”, SHIFT, and S key as a keyboard short cut is even quicker.
    K1ESE
  • Steven WA8Y
    Steven WA8Y Member ✭✭
    edited June 2019
    Thanks David and Dudley,  this is the snipit I made.  Dudley, your Win10 tip helped me find Snipit.
