picture post suggestion
dlwarnberg
Posting picture in the form I've noticed is all over the place, some seem to be taking pics with a phone...
Anyway there is a very simple program in windows that I use that works very cleanly.. it's called "snipit"
Simply open whatever it is you want to post about, open snipit, select "new", you will get a set of cross hairs to "snip" whatever in the box you create.. the snip will then show up, you can leave it as is, circle part of your snip, once you are happy with what you have then simply save it ..
in your post now just select the camera and drag your saved file to the box area.
It works really well.. this is however just for windows
hope this helps someone out there as pictures really help
Even easier, press Alt-PrintScreen. This takes a snapshot of the current window and saves it to the clipboard.
That works as well... the advantage of snipit is you only grab what you want and you can highlight, edit on the fly..
I just use Print screen and edit in Paint, at least on the Windows side. I use Photoshop on my Mac with Grab to take the image.0
Integral to Windows is the Snipping Tool. No 3rd party software involved. Works a treat...1
If you use the “Windows key” and S key as a keyboard short cut to “Snipping Tool” , just a little quicker in Win10. Dudley WA5QPZ1
The “Windows key”, SHIFT, and S key as a keyboard short cut is even quicker.
K1ESE0 -
Thanks David and Dudley, this is the snipit I made. Dudley, your Win10 tip helped me find Snipit.
- 334 Community Topics
- 601 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 399 SmartSDR for Mac
- 263 SmartSDR for iOS
- 247 SmartSDR CAT
- 184 DAX
- 371 SmartSDR API
- 9.1K Radios and Accessories
- 17 Aurora
- 170 FLEX-8000 Signature Series
- 912 Maestro
- 52 FlexControl
- 880 Genius Products
- 318 Tuner Genius XL
- 116 Antenna Genius
- 279 Shack Infrastructure
- 196 Networking
- 137 Contesting
- 730 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 949 Third-Party Software
