Smart SDR wont connect to internet after upgrade to V3
PhilipG
Smart SDR was working in previous version, after upgrade I get message "radio not connected to internet". I suspect that this is a port problem, but I am unable to figure out how to tell SmartSDR and Flex which ports to use (I had previously opened them in the router when using 2.49). I do not have plug and play, so I opened the ports manually. When I click the test button in setupscreen, it just waits "testing connection..." The Flex is working on the LAN.
Philip,
The radio needs an Internet connection to complete the licensing process for v3. If your radio is connected directly to your PC via an Ethernet cable, it will not have Internet access without some additional setup.
If you connect your radio to your router and then turn it on, that should be all that is required. How is your radio connected to your network currently?0
- 394 Community Topics
- 670 The Flea Market
- 177 SmartSDR+
- 453 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 80 Aurora
- 982 Maestro
- 954 Genius Products
- 350 Tuner Genius XL
- 130 Antenna Genius
- 312 Shack Infrastructure
- 218 Networking
- 146 Amateur Radio Interests
