Smart SDR wont connect to internet after upgrade to V3
PhilipG
PhilipG Member ✭✭
Smart SDR was working in previous version, after upgrade I get message "radio not connected to internet". I suspect that this is a port problem, but I am unable to figure out how to tell SmartSDR and Flex which ports to use (I had previously opened them in the router when using 2.49). I do not have plug and play, so I opened the ports manually. When I click the test button in setupscreen, it just waits "testing connection..."  The Flex is working on the LAN.
  • Abed - AB5ED
    Abed - AB5ED Inactive Employee
    edited June 2019
    Philip,
    The radio needs an Internet connection to complete the licensing process for v3.  If your radio is connected directly to your PC via an Ethernet cable, it will not have Internet access without some additional setup.
    If you connect your radio to your router and then turn it on, that should be all that is required.  How is your radio connected to your network currently?
