interference
Michael N3LI
Michael N3LI Member ✭✭
edited June 2019 in SmartSDR for Windows
I've been having interference during the daytime hours, worst on 160 and 80, and visible but not terribly bad on 40. I've gone through the house and turned off everything, unplugged all the wall warts, and it isn't in here, although I didn't **** the power to the entire house and run off battery.  I've attached a screenshot. Anyone see anything like this?
«1
  • Steve Sterling
    Steve Sterling Member ✭✭
    edited June 2019
    Looks like my neighbor's heat pump/air conditioner.  They have a Lennox.
  • Robert Lonn
    Robert Lonn Member ✭✭
    edited June 2019
    Anyone Close have SOLAR on their roof????
  • Roger Thompson AD5T
    Roger Thompson AD5T Member ✭✭
    edited June 2019
    Looks a lot like the Ethernet LAN interference shown at https://www.nk7z.net/wp-content/uploads/2018/01/Ethernet-wide.png
    Roger, AD5T
    edited June 2019
    Hi Michael
    I saw that on 6M.  In my case, I replaced 1 patch cable with one I made personally and trusted.  And, that fixed it.
    If you haven't look closely on your patch cables.
    va3mw
  • Michael N3LI
    edited June 2019
    I'll have to pay them a visit. Both have natgas though.
  • Michael N3LI
    edited June 2019
    It sure does. Different band, but similar spacing.
  • Michael N3LI
    edited June 2019
    Hi Michael, I'll take a look at all of them. Might try running direct from the Maestro with the max number of other cables unplugged.
  • Mark NS9N
    Mark NS9N Member ✭✭
    edited June 2019
    Run the radio on battery and shut your mains off. I had the same issue from a wall wart power supply that I forgot was connected. With the mains off if it is still there then it is time to figure out which neighbor is causing the issue. In this case some fox hunting skills come in handy with a SDR receiver connected to a laptop and a directional antenna. If it is not in your house then the fun begins, how well do you really know your neighbors?
  • Michael N3LI
    edited June 2019
    The neighbors here are pretty nice folks. I wouldn't expect any real issues. The interesting thing is the house beside me is rented by people who are seldom there, and the other side they are seldom home. Some might say the ideal neighbors!
  • EA4GLI
    EA4GLI Member ✭✭✭
    edited June 2019
    Try unplugging usb devices in the computer.
  • Michael N3LI
    edited June 2019
    I tried that, with no luck 8^(
  • DV
    DV Member ✭✭
    edited June 2019
    Try using a different computer and listen to those bands while the main computer is off. It looks like switching supply interference and some of us never think to check the computer we are running SmardSDR on.
  • Scott Russell - N1SER
    Scott Russell - N1SER Member ✭✭
    edited June 2019
    I get this on 40m, happens several times during the day at about the same time every day. Screenshot taken from this video. https://youtu.be/_neGlivzDjw
  • Michael N3LI
    edited June 2019
    Whoa! That is some freaky looking stuff
  • Michael N3LI
    edited June 2019
    I tried it with DogPark on my Mac. Same noise.  Added to the mystery, it is 8:20 p.m. EDT, and the noise is gone. I had a meeting at 5:30, so I wasn't here when it went away. It will likely be back tomorrow.
    edited June 2019
    Yeah no kidding right? It’s driving me nuts.
  • Norm - W7CK
    Norm - W7CK Member ✭✭
    edited June 2019
    Looks a lot like a MPPT solar charge controller.  They act like a switching voltage regulator converting sometimes >100v down to 12, 24 or 48v used by the battery system.  The controller must be really hard to filter because they all send the switching frequency as a darn signal out over the wire all the way back to the panels.  The panels and wiring act as a huge transmitting antenna.  Not very likely anyone in your neighborhood is charging a battery bank with solar though.
    Does anyone have a RV parked close by?  If it is plugged in, the chargers on them are terrible. Lots of noise.  Just cruise through a RV park with your HF gear running in your vehicle.  S9+15 noise.....
    Some folks also have solar on their RV to keep batteries topped off.   If they are using an MPPT controller, you'll know it.
    Another culprit I recently ran into was a Cisco POE Ethernet Switch.  I bought two of these to power my POE security cameras.  Terrible noise generators.  I couldn't quiet them down much at all and gave up.  I have since sold them on Ebay and replaced them with NetGear POE Switches.  Although they aren't perfect, I have been able to clean them up enough to no longer be an issue.
    Noise and HOAs are taking some of the enjoyment out of this hobby......
    Norm - W7CK
  • Eric Gruff
    Eric Gruff Member ✭✭
    edited June 2019
    You might contact KQ6RS (see QRZ.com) - this looks like a solar system and he's been tracking down many in his neighborhood as one particular brand is especially prone to QRMing many frequencies. Randy also published an article in a recent issue of QST on the same subject.
    edited June 2019
    There is a house down the street that had solar installed. The systems they install here do not charge batteries, they just use the solar power during the day. I’ve been wondering about this house. Other than that no RV’s allowed in the neighborhood.
    edited June 2019
    Thank you, I will for sure.
  • dlwarnberg
    dlwarnberg Member ✭✭
    edited June 2019
    Lots of Solar Pool pumps coming online these days, panels ramp up the controller and the DC pool pump will also ramp up as the sun gets higher in the sky... if a neighbor has a pool look for 3 or 4 solar panels on the roof is all.. not a full array...
    Yeah I had one, we've moved... DC pumps are the worst.
  • Paul - GI4FZD
    Paul - GI4FZD Member ✭✭
    edited June 2019
    I had similar interference to Michael but on 17meters, I only noticed that they were not on my ipad, narrowed it down to my computer monitors, both made by AOC, so going to have to source interference free 23" monitors, any suggestions?
  • Mark NS9N
    Mark NS9N Member ✭✭
    edited June 2019
    Dell monitors have been flawless. Four of them running at my station and zero interference.
  • wa4wab
    wa4wab Member ✭✭
    edited June 2019
    17,20 & 40 are the ones I have issues with. Will look into some of the suggestions posted above. Thanks
    edited June 2019
    Eric, so to follow up, I emailed Randy and he replied very quickly and said my RFI doesn’t look like solar since it’s not continuous. He thinks it’s something else. So I re-read his QST article and ordered the W6LVP Loop Experimenters Kit so I can make the small loop Randy used for direction finding the source. So we’ll see how that works once I get it all setup. It will be a fun project. Thanks for the recommendation and reminder of the QST article, I remember reading it but forgot about it. :) 73, Scott N1SER
  • Eric Gruff
    edited June 2019
    Scott - great. Randy's a great guy with a career in RF engineering behind him. Good luck in solving the QRM issue!
  • wa4wab
    wa4wab Member ✭✭
    edited June 2019
    I was able to pin point my source of interference, it is the monitor in this case. It sits three inches away from the 6400M, will try and put more distance between them and see what happens.  Anyone have ideas on how to filter this kind of thing out?
  • Eric Gruff
    edited June 2019
    For those of you with monitor QRM, a first step is putting good-quality snap-on ferrites on all leads going to the monitor(s) and radio, including coax. If the interference is strong enough to radiate directly into the radio, physical separation or replacing the monitor(s) are your best choices.
  • Dave - W6OVP
    Dave - W6OVP Member ✭✭
    edited June 2019
    That's always step 1. Make sure it's not in your house.
    Then ran the FLEX 6300 on a UPS and monitored it with an iPad.
    Then used a portable AM radio to chase down the culprit. It was a new Keurig automatic coffee maker that radiated S8 when was plugged in but switched OFF! Adding an inline AC switch solved that problem (when not actually making coffee).
  • N8AUM
    N8AUM Member ✭✭
    edited June 2019
    Lucky that you found it! I have soo much RFI that I don't know where to begin. A major problem I found are the new LED lights, made in China of course.
