Profile Manager Problem
Pat ON3CQ
I have installed V2.5.1 and created new profiles. Created 25W in Transmit profile. If I close SmartSDR and restart it, this profile will remain 25W. I have the problem that I switch off my Flexradio 6300 and restart it later, the Transmit profile has been deleted. The rest of the Profile Global and Microphone will all remain available. Anyone know what the problem is ?
Pat ON3CQ
Pat ON3CQ
Pat are you saying that your radio is starting up on a different profile than the one you saved?0
Pat, did you save the profile?0
Remember that if your new profile is saved correctly, it will show up on the control panel as the name you called it. Remember to press save before exiting.0
No Bill I only have 1 profile 25W and Default.
Yes Bob i save the profile.
Bill this are my profile i make. I switch off my Flexradio 6300 and restart, the Transmit profile has been deleted. The rest stay how i make it.
What does it show here?
In profile manager make sure TX profile is sellected to see your saved profile. You have Globle sellected
Also you can make an mic profile with the same name...
It looks like it save ok in the box to the right.0 -
This my TX Band Settings. And i start back and the Tranmit Profile only Default the system remove my 25W.
So there ya go.. take the Tune PWR column and set them the way you want. You should be able to directly input the power you want.. i.e. 15 or 20 or 25..0
Bill the blank TX Band Settings works as you posted. Then created a new Profile and now keep the 25W. When I restart the flexradio, it keeps the settings now. Thank you all for the info and help.
Glad that things are ok now...1
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 93 Aurora
- 988 Maestro
- 963 Genius Products
- 353 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
