Profile Manager Problem
Pat ON3CQ
I have installed V2.5.1 and created new profiles. Created 25W in Transmit profile. If I close SmartSDR and restart it, this profile will remain 25W. I have the problem that I switch off my Flexradio 6300 and restart it later, the Transmit profile has been deleted. The rest of the Profile Global and Microphone will all remain available. Anyone know what the problem is ?
Pat ON3CQ
Pat ON3CQ
Pat are you saying that your radio is starting up on a different profile than the one you saved?0
Pat, did you save the profile?0
Remember that if your new profile is saved correctly, it will show up on the control panel as the name you called it. Remember to press save before exiting.0
No Bill I only have 1 profile 25W and Default.
Yes Bob i save the profile.
Bill this are my profile i make. I switch off my Flexradio 6300 and restart, the Transmit profile has been deleted. The rest stay how i make it.
What does it show here?
In profile manager make sure TX profile is sellected to see your saved profile. You have Globle sellected
Also you can make an mic profile with the same name...
It looks like it save ok in the box to the right.0 -
This my TX Band Settings. And i start back and the Tranmit Profile only Default the system remove my 25W.0
So there ya go.. take the Tune PWR column and set them the way you want. You should be able to directly input the power you want.. i.e. 15 or 20 or 25..0
Bill the blank TX Band Settings works as you posted. Then created a new Profile and now keep the 25W. When I restart the flexradio, it keeps the settings now. Thank you all for the info and help.0
Glad that things are ok now...1
- 328 Community Topics
- 594 The Flea Market
- 7.8K Software
- 6.2K SmartSDR for Windows
- 396 SmartSDR for Mac
- 260 SmartSDR for iOS
- 246 SmartSDR CAT
- 179 DAX
- 369 SmartSDR API
- 9.1K Radios and Accessories
- 15 Aurora
- 161 FLEX-8000 Signature Series
- 909 Maestro
- 51 FlexControl
- 873 Genius Products
- 312 Tuner Genius XL
- 115 Antenna Genius
- 278 Shack Infrastructure
- 196 Networking
- 438 Remote Operation (SmartLink)
- 135 Contesting
- 723 Peripherals & Station Integration
- 136 Amateur Radio Interests
- 943 Third-Party Software
