Amplifier Drive Input... 5w / 10w / 50w?
Dwayne_AB6A
Hey all, is there a recommended or preferred drive input for an amplifier connected to a Flex-6600? I'm considering a new 1K amp and some amps have the ability to specify drive input?
Each amp will have different drive requirements, and drive requirements will also differ slightly per band too. Check the amp's manual to determine its input power range.
Dwayne, I have an SPE 2K and the SPE amps lets you control the drive level from the Flex if you connect them via CAT. Mine varies from about 32 to 40 watts for 1,500 out and somewhat less for 1,000 out.0
It all depends on the amp. I have one amp that requires just 3 watts drive for 300 watts out and another amp that requires almost 50 watts drive ( which would completely fry the first amp ) to get the same 300 watts out
Nobody has answered your question.
I assume the FLEX is the cleanest at just under full power, like maybe 80-90w, since its output transformer has been likely designed and compensated around this power level.
But only FLEX knows for sure. Whatever level it operates the cleanest would be the ideal input power to your linear.
Rob.
www.N4GA.com
At the Mid-power level (1K), which is where I usually run it, my SPE 1.3-K only requires 6-7 watts. Anything over that is overdriving it. On most bands, for 1.5K, it's 10-11w.
Rick, W0FG0 -
My RF Kit B26 2K+ takes about 10-15 watts for 160-10 (minus 30m where we can go 1500w!) I haven't really tried it on 6m but I hear it can take as much as 60w to get 500w out. But each model of amp (and probably each sample within a model) can take different power.
- 394 Community Topics
- 670 The Flea Market
- 177 SmartSDR+
- 453 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 80 Aurora
- 982 Maestro
- 954 Genius Products
- 350 Tuner Genius XL
- 130 Antenna Genius
- 312 Shack Infrastructure
- 218 Networking
- 146 Amateur Radio Interests
